1991 Ford Escort Won't Go Into Gear
KPERRY316
Make and Model: Ford Escort GT
Year: 1991
Mileage: 88,000
Please Help! I replaced the clutch in my Escort and put eveything back together and bled the clutch system. After starting the car and depressing the clutch pedal, it won't go into gear. Furthermore, it won't start at all when you put it in gear first then turn the ignition key. I'm at my wits end...please help!
Mike
Dec 20, 2006 at 3:21 PM
CARUNDELL
  • 602 POSTS
[quote:1f41b4983b="kperry316"]Make and Model: Ford Escort GT
Year: 1991
Mileage: 88,000
Mike[/quote:1f41b4983b]
Hey Mike,
First lets verify the clutch hydraulics, have someone depress the clutch pedal while you visually look at the slave plunger or clutch lever. It should move at least 1 1/2 to 2 inches! if not your bleed was unsuccessful. when you bleed those, don't bleed them like brakes. Don't allow the plunger to go all the way back when you bleed, stop before as they will tend to suck back in air because the pressure plate is pushing against it! If all is ok with the hydraulics then your going to have to (and I hate to say this!!) double check your work, on some vehicles, its too easy to put in the clutch disc backwards! Which is another possible cause of your problem! On the disc it will say "flywheel side or engine side" Let us know!
Chris
Dec 20, 2006 at 6:52 PM
Suggested Repair
Have a helper depress the clutch pedal while you watch the slave plunger or clutch lever; it should move about 1.5 to 2 inches. If it does not, rebleed without letting the plunger return fully, since it can draw air back in. If travel is adequate, recheck the clutch disc orientation; the disc is marked flywheel or engine side and may have been installed backward.
Conversation Summary
After replacing and bleeding the clutch on a 1991 Ford Escort GT, the owner could not shift into gear with the pedal depressed, and the car would not start if placed in gear before turning the key. The expert advised verifying that the slave plunger or clutch lever moves 1.5 to 2 inches, rebleeding without letting the plunger fully return, and checking that the clutch disc was not installed backward.
