1995 Ford Escort Won't Shift Into Gear
DFITZSIM
We took our 1995 Ford Escort on a 1200 mile trip, the following day upon our return home I took the car to the library (2 miles). The car began to smell and smoke was coming from under the hood. I pulled over, called my husband. The thermostat did not go up, so I didn't think it was the coolant. Since we lived just up the road my husband started the car again, the engine ran fine, so he headed home (1 mile) A few hundred feet from our house the car began to smoke again and wouldn't go up a small incline. We pushed it home. We added coolant and transmission fluid. The following day we tryed to start it and it wouldn't go into gear. You can move the shift handle but the transmission does not move into any gear. We also found a leak under the car after if sat for awhile. Is the transmission blown?
Dec 31, 2006 at 1:43 AM
TAURUSWHEEL
  • 718 POSTS
I'm not a trans expert, but smoke anytime is not good,, find a reliable trans shop for diagnosis, then decide if it's worth the money.. i spent about 1800 for a trans in my 94 Taurus this past spring, however the car is mint condition..
Dec 31, 2006 at 8:48 AM
Suggested Repair
Have a reliable transmission shop diagnose the transmission after the smoke, fluid leak, and failure to engage any gear, then decide whether repair or replacement is worthwhile.
Conversation Summary
A 1995 Ford Escort smoked under the hood after a long trip, would not climb a small incline, and later would not engage any gear despite the shifter moving. Coolant and transmission fluid were added, and a leak appeared after the car sat. The reply advised a professional transmission diagnosis before deciding on the cost of repair.
