1996 Ford Escort not shifting right
TERRY BURKHART
  • 1996 FORD ESCORT
Transmission problem
1996 Ford Escort 4 cyl Front Wheel Drive Automatic 170+ miles
transmission not shifting to 2nd, just changed fluid and filter. It shifts if you let off the gas though and after that it is fine. Dont matter if it is cold or warm the first time. Sometimes go down the road and stop and start driving again it works. I changed the fluid because before it would really slip and then eventually not go at all. Looked really brown.
Monday, March 15th, 2010 AT 10:17 AM
DAVE H
  • 13,384 POSTS
Brown ATF fluid = burning internally somewhere. Probably 2ng gear clutches. Eventually you will need to have the trans rebuilt. The fluid replacement will only last for a little while longer
Thursday, March 18th, 2010 AT 6:00 AM
