1998 Ford Escort Won't Shift After Swap
Suggested Repair
Confirm the salvage transmission is the correct unit for the Escort. The extra cable is likely a throttle detent/kickdown cable, not an overdrive cable; connect it to the throttle and adjust it. An unconnected detent cable should not prevent driving, only downshifts, so also investigate the no-shift, whine, and transmission temperature/code faults.
Conversation Summary
A 1998 Ford Escort would not shift and whined after a salvage transmission was installed. The replacement had a cable the old unit lacked, though the console indicated overdrive, and post-install codes included no transmission temperature reading. The expert said the transmission is likely wrong and identified the cable as a detent cable that hooks to the throttle and is adjusted; if disconnected it should affect only downshifts, not prevent driving.
