1993 Ford Escort Won't Shift to 2nd
MRFIXIT1951
When the car is first started up the automatic transmission will not shift into 2nd gear unless I really get on the accelerator. Once it shifts, everything is fine all day long, untill I turn off the engine and restart it. Then I have to go thru the whole thing again. Anyone have any ideas?
Nov 27, 2006 at 12:11 PM
CATCH_15
  • 250 POSTS
Anytime you have problems with an automatice transmission, the first thing to do is always check the fluid level. Since the fluid not only lubricates the moving parts, but actually performs the work through hydrolics.
Nov 28, 2006 at 5:46 AM
Suggested Repair
Check the automatic transmission fluid level first. Low fluid can prevent proper hydraulic pressure and cause hard or delayed shifts.
Conversation Summary
The owner of a 1993 Ford Escort says the automatic transmission will not shift from 1st to 2nd after a cold start unless the accelerator is pressed hard. Once it shifts, it works normally until the engine is restarted. The expert recommends checking the transmission fluid level first because the fluid lubricates the transmission and applies hydraulic pressure for shifts.
