1991 Ford Escort Brakes Overheating
STEVEC_R
I have a 1991 ford escort gt 1.8L (150,000miles) and i recently change the brakes, calipers, and rotors. Then the brakes,rotors,calipers, and rims got really hot. I was told it was the calipers seizing up, so i returned the rotors, and calipers, and got new ones. So then i put everything back on, bled the brakes, and master cylender till all the air was out, and now its getting hot again. what could be my problem?
Mar 16, 2007 at 12:48 PM
PEPPERMRJ
  • 1,158 POSTS
I b thinkin brake hose/s. Also check the metal lines for kinks or crushing. Jack the car up and put it on stands. Apply the brakes several time and then try to spin the wheels.
Good hunting and let us know. :)
Mar 16, 2007 at 1:46 PM
Suggested Repair
Inspect the brake hoses and metal lines for kinks, crushing, or internal collapse that can trap pressure. With the car safely on stands, apply the brakes several times, then try to spin each wheel to see if a caliper is dragging.
Conversation Summary
A 1991 Ford Escort GT owner replaced the brakes, calipers, and rotors, then found the brakes, rotors, calipers, and rims getting very hot. After replacing the parts again and bleeding the brakes and master cylinder, the overheating continued. The expert suggested checking the brake hoses and metal lines for kinks or crushing, then applying the brakes and trying to spin the wheels with the car raised.
