1998 Ford Escort No Power After Battery
MEGENTILE
I just replaced my car battery......and there is no power at all...lights, radio, anything let alone starting the car. I had the battery checked and it's good.
What might be the probem.
Nov 10, 2007 at 5:02 AM
  • 75,988 POSTS
Check all your fusible links maybe at the starter relay or in a power distribution box it has to go thru there to get inside the vehicle.
Double check all connections make sure it clean and tight to include the relay/and starter battery cable terminal
Nov 10, 2007 at 5:10 AM
Suggested Repair
Check fusible links at the starter relay or power distribution box, and verify all battery, relay, and starter cable connections are clean and tight.
Conversation Summary
After replacing the battery on a 1998 Ford Escort, the owner had no power to the lights, radio, or starter even though the battery tested good. The expert advised checking fusible links at the starter relay or power distribution box and confirming that all related connections, including the relay and starter battery cable terminal, are clean and tight.
