I recentrly put a new cd player in my car... Well it worked good for a few months then i took it out and put it back in... Now when i leave my car sit for liki more then 10 hours my battery goes dead unless i pull my fuse out for my cd player or unhook it everythime i get out. any ideas?
1998 Ford Escort Battery Drain After Stereo
Ok i have a 1998 ford escort zx2 with 121000 miles on it its a 2 door .manual.
Jul 31, 2007 at 3:17 PM
[quote:3fe2875323="bilsonxnc"]Ok i have a 1998 ford escort zx2 with 121000 miles on it its a 2 door .manual.
I recentrly put a new cd player in my car... Well it worked good for a few months then i took it out and put it back in... Now when i leave my car sit for liki more then 10 hours my battery goes dead unless i pull my fuse out for my cd player or unhook it everythime i get out. any ideas?[/quote:3fe2875323]
Not sure if this might help. Does your CD player works even if you turn off your ignition key? If yes, then you connected the (+) accessory wire and the (+) battery wire together. Usually red and yellow wire. Accessory (+) wire should be connected to (+) 12v in which it should turn off (no power) when ignition key is off. A good source for (+) accessory wire is the (+) wire of the cigarette lighter. Just make sure you still have the (CD player) fuse between the (+) accessory source and the CD player.
Aug 1, 2007 at 4:47 PM
Suggested Repair
Check whether the CD player still has power with the ignition off. If it does, the constant battery wire and ignition accessory wire were likely joined. Connect the accessory lead to a source that loses power with the key off, such as the cigarette lighter positive, and keep the CD player fuse between that source and the player.
Conversation Summary
A 1998 Ford Escort ZX2 battery dies after sitting more than about 10 hours following reinstallation of an aftermarket CD player. Removing the CD player fuse or disconnecting the player prevents the drain. The expert says the constant and accessory power wires may be connected together and recommends powering the accessory lead from a switched source such as the cigarette lighter, with the fuse still in line.
