1995 Ford Escort Battery Terminal Acid
VTCAROL50
  • 22 POSTS
I'm getting an acid buildup on my battery terminals which is preventing the car from sometimes starting?
Can I replace the terminals to correct this problem or is it a problem with the battery itself, that is throwing out this acid?
Any suggestions appreciated.
Jan 23, 2007 at 2:41 AM
MATHIASO
  • 1,209 POSTS
check the cables for continuity if they are bad replace them, check your battery with an ohmeter.
the acide build up may have cause shorted cell .
Test it, recharge it or replace it.
Sometimes battery failure is not the fault of the battery at all. It may be caused by a bad starter, a defect in the charging system, or just a loose belt.
Check those things too.
Jan 23, 2007 at 3:17 AM
Suggested Repair
Check battery cable continuity and replace any bad cables. Test the battery for a possible shorted cell from acid buildup, then recharge or replace it. Also inspect the starter, charging system, and belt tension.
Conversation Summary
The owner of a 1995 Ford Escort reports acid buildup on the battery terminals that sometimes prevents starting and asks whether the terminals or the battery should be replaced. The expert advises checking cable continuity, testing the battery for a possible shorted cell, and also checking the starter, charging system, and belt.
