1999 Ford Escort 95 Amp Alternator
LASVEGASWHITEHOUSE
On my 1999 Escort SE I have a 95 amp alternator. Can I replace it with the 75 amp unit since it is less expensive?
Aug 24, 2007 at 3:53 PM
  • 75,988 POSTS
[quote:8f18293344="lasvegaswhitehouse"]On my 1999 Escort SE I have a 95 amp alternator. Can I replace it with the 75 amp unit since it is less expensive?[/quote:8f18293344]
Match up the bolt patterns/pulley
There's a reason why for 95amp-if for some reason you go for the 75amp and half of your electrical system is not functioning right then you have to go back to the 95amp. Hoping there's no damage to any system.Remember its electrical non refundable.
Aug 24, 2007 at 10:44 PM
Suggested Repair
Keep the original 95-amp alternator. A 75-amp unit may not support the electrical load and could leave systems underpowered. If a substitute is considered, match the bolt pattern and pulley, and remember electrical parts are typically non-refundable.
Conversation Summary
The owner of a 1999 Ford Escort SE asked whether a less expensive 75-amp alternator could replace the original 95-amp unit. The expert said any substitute must match the bolt pattern and pulley, but warned that the lower output may cause electrical problems and that electrical parts are non-refundable, so the 95-amp alternator should be retained.
