Electrical problem
1999 Ford Escort 4 cyl Two Wheel Drive Manual
My question is after I have removed the alternator and bought a new one how do I properly install it? Big question is how do I loosen and unloosen the belt?
Friday, March 6th, 2009 AT 11:06 AM
DAVE H
MECHANIC
GENERATOR
Removal & Installation
Disconnect negative battery cable. Disengage drive belt from pulley. Remove power steering hose bracket from generator bracket. Remove generator mounting bolts. Remove generator. Disconnect wiring from generator. To install, reverse removal procedure. Tighten lower generator bolt to 15-22 ft. lbs. (20-30 N.m). Tighten upper generator bolt to 29-44 ft. lbs. (40-55 N.m).
