A/C 1999 ford escort 4 cy
1999 FORD ESCORT
RAYCZECK
  • 6 POSTS
compressor is not getting any power to it , I jumped the pressure switch and still no power. Fues is good
every thing I have check is good is there a nother
relay if so where
Apr 28, 2007 at 8:40 AM
RAYCZECK
  • 6 POSTS
[quote:b146dc327f="justanold"]HELLO! Yes there is another relay but the cost is about $200.00. before we begin i have a few simple tests with a test light. engine running..A/C on..do you have power at the pressure sw. if so..install jumper wire across leads..on to the compressor..turn the eng. off.. remove connector from comp. restart engine with A/C on..test for power. get back to me with your results. 8) 8) 8)[/quote:b146dc327f]
There is no power.
Apr 28, 2007 at 10:23 AM
RAYCZECK
  • 6 POSTS
[quote:f5e831eaa6="justanold"]HELLO! There is no power where? the more info i get the better off you are. 8) 8) 8)[/quote:f5e831eaa6]
There is no power coming out of the wires going into the compressor.Like I said the fues is good I replaced it just to make sure.
Apr 28, 2007 at 1:36 PM
RAYCZECK
  • 6 POSTS
[quote:fa3018a583="justanold"]HELLO! May i assume then that you had power at the cycling sw. and that you properly jumped it and had the car running when you tested for power at the comp.? we can test it further or you can replace your CCRM. let me know how you want to proceed. 8) 8) 8)[/quote:fa3018a583]
Yes that is right,there was still no power
so I got a jumper wire and jumped the compressor from the battery to check the compressor
and it came on so I recheck the fues and it was good
If there is something else I can check I will
Apr 29, 2007 at 2:15 PM
RAYCZECK
  • 6 POSTS
What is a ccrm
Apr 29, 2007 at 2:20 PM
RAYCZECK
  • 6 POSTS
is this a black box under the air filter
Apr 30, 2007 at 1:15 PM
