1999 Ford Escort air conditioning
BRITAYLOR
  • 1999 FORD ESCORT
  • 4 CYL
  • MANUAL
  • 90,000 MILES
The air conditioning will not blow out cold air. Tried charging the system but it will not take any freon. The compressor is working and runs continuously. What could it be?
Thursday, July 31st, 2008 AT 10:04 AM
MASTERTECHTIM
  • 4,750 POSTS
Most likely if the system is charged, either the compressor failed internally or the blend door in the dash is stuck on heat. Look under the dash while you turn from hot to cold and see if you can see the door move, possibly the actuator rod popped off
Friday, August 1st, 2008 AT 7:01 AM
