1999 Ford Escort AC PROBLEM!!
80,000 MILES • 4 CYL • FWD • AUTOMATIC
DGREAT
My Ac is currently not pushing out cold air. Tehe compressor is not broken, but i cant get it to go on, would you have any ideas? of any wiring diagrams for me to look at?
thanks for help!
Aug 31, 2008 at 11:53 AM
LEGITIMATE007
  • 5,121 POSTS
if the compressor wont come on ,its usually one of two things, either the high pressure switch is bad, or there is a leak in the system which is not allowing it to build up enough pressure to turn the compressor on. check the switch itself, it could be faulty
Aug 31, 2008 at 1:04 PM
