1998 Ford Escort Brake Light Flickers
MJTZERO
Hi, I have a 98 Ford Escort with 183000 miles on it. My problem is that when I drive the brake light on the dashboard(The one that lights up when you set your parking brake) will come on and off randomly. For example when I drive up the street and then come to a complete stop,nothing happens, but sometimes when I resume driving, the light will come on for a few seconds but then go out. Sometimes it doesn't happen at all, others times it will random come on and then go out. Thank you.
Sep 3, 2007 at 4:10 AM
MERLIN2021
  • 17,250 POSTS
It's probably time for new brakes! The front disc brakes draw fluid down in the master cylinder as the pads wear, when enough fluid draws down into the calipers, the light comes on! Check your brakes!
Sep 3, 2007 at 4:13 AM
DSPLC
  • 220 POSTS
[quote:3c9dddb144="mjtzero"]Hi, I have a 98 Ford Escort with 183000 miles on it. My problem is that when I drive the brake light on the dashboard(The one that lights up when you set your parking brake) will come on and off randomly. For example when I drive up the street and then come to a complete stop,nothing happens, but sometimes when I resume driving, the light will come on for a few seconds but then go out. Sometimes it doesn't happen at all, others times it will random come on and then go out. Thank you.[/quote:3c9dddb144]
(maybe only) You just need to add brake fluid in the brake master cylinder reservoir. If it is low on fluid, there is a sensor (electric wire connected on the side of the reservoir) that lights up the dashboard brake light. When you are driving, the brake fluid in the reservoir shakes, turning the light on and off when fluid is low.
Cause of low fluid, most of the time as Merlin2021 wrote "brake pads wear" .
By the way, that is not ABS light. If it is ABS light, then there is something wrong with your Anti-lock Brake System. Not the brake pads or the brake fluid.
It is the light showing " Brake P & I ", Anti-lock Brake System shows letters "ABS" light.
Sep 3, 2007 at 6:14 AM
MERLIN2021
  • 17,250 POSTS
Do the brakes...disregaurd this post, when you push the caliper pistons back in, it will refill the reservoir!!!
Sep 3, 2007 at 8:29 AM
Suggested Repair
Check the brake fluid level in the master cylinder reservoir and inspect the brake pads for wear. Low fluid from worn pads can make the brake warning light flicker as fluid moves; top up fluid if low and service the brakes as needed.
Conversation Summary
The owner of a 1998 Ford Escort reported the parking-brake warning light coming on and off randomly while driving. Experts said this is usually caused by low brake fluid from worn brake pads, which lets the reservoir sensor trigger intermittently as the fluid moves. They advised checking the fluid level and brake condition, and clarified that this is the brake warning light rather than the ABS light.
