1997 Ford Escort Brake Lights Stay On
PALMERWOMAN
Sometimes when I shut my car off and get out to walk away I notice that my break lights are still on. If I tap on the break pedal they shut off. It doesn't happen all of the time and I have been trying to remember to just tap the break before I get out. But I sometimes forget and my battery is run down by the next morning. Dad said to spray WD40 on the break pedal but I'm not sure that will do the trick. Any help is appreciated!
Apr 17, 2007 at 5:26 AM
BACKYARDMECHANIC
  • 337 POSTS
The brake pedal is hinged at the top of it. Follow the bar up to the top and you will see where it is hinged from. This is where you can spray a little oil if the pedal is not coming up all the way. If this doesn't work then the spring make be weak/broken or the brake switch may need to be adjusted.
Apr 17, 2007 at 6:23 AM
Suggested Repair
If the brake pedal is not returning fully, apply a little oil at the hinge at the top of the pedal. If that does not help, check for a weak or broken return spring or adjust the brake light switch.
Conversation Summary
The owner of a 1997 Ford Escort says the brake lights sometimes stay on after the car is shut off and can drain the battery overnight. Tapping the brake pedal turns them off. An expert advises oiling the pedal hinge if the pedal is not coming up fully, and if that fails, checking a weak or broken spring or adjusting the brake switch.
