1997 Ford Escort outside brake lights constantly on!
NATERE2
  • 1997 FORD ESCORT
Electrical problem
1997 Ford Escort 4 cyl Two Wheel Drive Manual
ok, I am not sure when this happened, pretty sure it was today as this morning I didnt notice anything wrong when driving to work
so, all lights seems to function save the brake lights.
the two on the outside are CONSTANTLY on and the window brake doesn't turn on either (when braking). So, essentially there is no response at all from the brake pedal to the lights. The two main lights stay on (even with the car turned off) and the 3rd brake light is always off.
I am not sure how to troubleshoot this. Any ideas?
thanks!
nate
Friday, April 25th, 2008 AT 4:29 PM
Check the brake switch on the brake pedal support either it needs adjustment or replacement. Also could be the electronic flasher it has to go thru here to get to the lights on the back on another constant power source.
Friday, April 25th, 2008 AT 4:57 PM
NATERE2
That worked, some blue plug was on the floor, and there was an extra one, we put back into assembly, and it work! Saved me $150.00, god bless this forum, I am grateful.
Friday, April 25th, 2008 AT 5:43 PM
