Welcome to the forum, as far as your brake lites. When the problem occurs, check the feed from the brake switch. The brake switch should be located close to brake pedal arm. The dark green should not be hot unless you are stepping on the brake. If it is hot, possibilities, the brake pedal arm or switch needs adjustment, where possible, The brake switch is faulty, The dark green wire is shorted to voltage somewhere and that is backfeed. One way to tell if the voltage is coming through the switch, Take the connector loose from the brake switch, if the green wire is still hot, it is shorted to voltage, somewhere.
SPONSORED LINKS
Tuesday, January 12th, 2010 AT 4:21 PM
