1997 Ford Escort Brake Lights Stay On
POPPAICEPICK
1997 ford escort 160000 miles. The brake lights will not turn off even if the car is not running...Any ideas
May 4, 2006 at 6:37 AM
LOSONE
  • 1,616 POSTS
You probably have a defective brake light switch
May 4, 2006 at 8:08 AM
JTR
I agree, it is very possible that the break light switch is bad. I have a Ranger, and I have had to replace the switch 4 times in about 10 years. good news is, it is pretty easy to replace, and in expensive, the switch is usually located on the break pedal linkage underneath the dash board, your local auto parts store should carry it in stock, I think I paid about $4 for mine, if you go to the dealer it will cost about $15.
May 4, 2006 at 11:13 AM
Suggested Repair
Replace the brake light switch, which is typically mounted on the brake pedal linkage under the dashboard. It is an inexpensive part commonly stocked at auto parts stores.
Conversation Summary
A 1997 Ford Escort with 160,000 miles has brake lights that stay on even when the car is not running. Replies point to a defective brake light switch on the brake pedal linkage under the dash, noting it is inexpensive and fairly easy to replace.
