1997 Ford Escort Brake Pedal to Floor
DSPLC
  • 220 POSTS
I have a 1997 Ford Escort, no ABS, front brake pads and rear brake shoes. (85,000 miles) When I am driving in the city, brakes are fine but when I am drivng in the freeway for about 30 minutes (non-stop), the moment I step on the brake pedal, the brake pedal is almost to the floor. I have to pump the brake pedal to get good brakes. Any suggestions? Thanks.
Jul 29, 2007 at 9:01 AM
BOOTDOG
  • 665 POSTS
sounds to me your master cylinder is failing.
Jul 30, 2007 at 1:42 AM
DSPLC
  • 220 POSTS
Thanks. I will change the master cylinder.
Jul 30, 2007 at 5:12 PM
Suggested Repair
Replace the master cylinder. The expert attributed the pedal dropping nearly to the floor after extended highway driving, requiring pumping to restore braking, to a failing master cylinder.
Conversation Summary
The owner of a 1997 Ford Escort without ABS reported normal city braking, but after about 30 minutes of nonstop freeway driving the brake pedal went almost to the floor and had to be pumped for good braking. An expert said the master cylinder was likely failing, and the owner planned to replace it.
