1999 Ford Escort Stalling when Idle
ASH459
Engine Mechanical problem
1999 Ford Escort 90000 miles
Hello, my car has been stalling (or just basically cuts off) when I idle for too long. It doesn't happen all the time but the frequency is increasing. I've had a tune up, I've changed the coils that the spark plugs go into, I've gotten some part that shifts the car into idle replaced, I believe I've gotten a new fuel filter. Many of these seemed to work for a short time, but now the problem is occuring again. PLEASE HELP!
May 8, 2008 at 12:46 AM
BMRFIXIT
  • 19,053 POSTS
check for codes
check for vacuum leaks
check clean and or replace idle air control valve
May 8, 2008 at 10:09 PM
ASH459
I checked the codes. The service engine light keeps coming on and it tells me that theres a problem with the ignition coil. I've replaced that 3 times. I've also replaced the idle control valve. I've gotten a new fuel filter/air filter and plugs. Now the car has begun shutting off when I press on the brake to come to a stop. I really hope you can give me some direction... PLEASE!!!
Jun 25, 2008 at 4:36 PM
BMRFIXIT
  • 19,053 POSTS
When you checked for codes what # did you get
check fuel pressure and injector
Have an automotive repair question!
Sign up and ask your automotive question !
Risk of fire.
Keep cigarettes, sparks, open flame, and other sources of ignition away from vehicle.
Gasoline, methanol, and oxygenated fuels are toxic and flammable and must be handled appropriately
Jun 25, 2008 at 10:27 PM
