1995 Ford Escort Stalls when idleing and loses power in tur
1995 FORD ESCORT
200,000 MILES • 4 CYL • FWD • AUTOMATIC
JOHNNIEDINVA
  • 6 POSTS
My escort wagon stalls often when idling in park, neutral or when I pull up to a stop light. This has been going on for a year. I recently had the ac fixed, and it doesn't stall if I have the Ac on, but does if the ac is off, same as it has before. It also loses power, even with accelerator pressed to the floor when going around turns, like on an on ramp to the highway. I've changed the IAC, fuel filter, and cleaned the maf sensor.
Any help is appreciated!!
Sep 1, 2010 at 11:39 PM
  • CERTIFIED EXPERT
  • 110,176 POSTS
Have you checked fuel pump pressure?
Sep 2, 2010 at 11:58 AM
JOHNNIEDINVA
  • 6 POSTS
Not yet, I will have to round up a pressure tester. Thanks for the input!!
Sep 2, 2010 at 12:10 PM
  • CERTIFIED EXPERT
  • 110,176 POSTS
Let me know what you find.
Sep 2, 2010 at 1:01 PM
JOHNNIEDINVA
  • 6 POSTS
ok, Fuel pressure reads about 38-40 with key on, then after it starts its down to about 32psi. When it cuts out, the pressure rises back to about 38ish.
Oh, and the car has a new IAC about 6 mo ago....
Sep 16, 2010 at 12:06 AM
  • CERTIFIED EXPERT
  • 110,176 POSTS
I think you need a new fuel pump. Pressure should be (KOEO) 64 to 85 PSI. (KOER) 31 to 38 PSI.
Sep 16, 2010 at 8:07 AM
JOHNNIEDINVA
  • 6 POSTS
Hmmm, I just found out that the car got a new fuel pump about 2 yrs ago. Also, something else to ponder....The car always starts right back up on the first try after it stalls, and I noticed that the engine only bogs down when making right hand turns, but not left hand turns.......any thought or reasoning behind this? Thanks so much for all your input.
Sep 16, 2010 at 9:31 AM
JOHNNIEDINVA
  • 6 POSTS
it bogs whether the tank is full or not
Sep 16, 2010 at 9:33 AM
  • CERTIFIED EXPERT
  • 110,176 POSTS
I've heard of that when the fuel is low in the tank.
Sep 16, 2010 at 10:25 AM
JOHNNIEDINVA
  • 6 POSTS
And, I found that it doesn't stall at idle with the AC running........
Sep 16, 2010 at 2:50 PM
  • CERTIFIED EXPERT
  • 110,176 POSTS
It sounds like a pump issue to me. Keep in mind, when at an idle, the engine doesn't need as much fuel. However when you drive, there is a higher demand. If the pump is weak (and it looks that way), it may not be keeping up with the engine's need.
Sep 17, 2010 at 7:18 AM
