1999 Ford Escort Idle
1999 FORD ESCORT
125,131 MILES • 4 CYL • 2WD • AUTOMATIC
BIGBROWNEYEZ4U
My 1999 ford escort stalls when the AC is turned on and the idle is very low when it is stopped, wants to stall when you give it gas. how can i fix it?
Feb 6, 2008 at 3:03 AM
BMRFIXIT
  • 19,053 POSTS
[quote:a8e8e34fa3="bigbrowneyez4u"]Engine problem
1999 Ford Escort 4 cyl Two Wheel Drive Automatic 125131 miles
My 1999 ford escort stalls when the AC is turned on and the idle is very low when it is stopped, wants to stall when you give it gas. how can i fix it?[/quote:a8e8e34fa3]
Check idle air control valve
clean /replace it
did you check tune up?
Feb 6, 2008 at 11:11 AM
