1999 Ford Escort Drain Plug Size
USPSGOLF
The AT is this vehicle has a case plug for draining. Any idea what size hex socket is used to remove this plug?
Apr 16, 2006 at 2:17 AM
LOSONE
  • 1,616 POSTS
They vary either 17mm or 15mm. Some are 16mm or 5/8
Apr 16, 2006 at 2:19 AM
Suggested Repair
The automatic transaxle drain plug hex size varies. Try a 15mm, 16mm, 17mm, or 5/8-inch socket.
Conversation Summary
The owner asked which hex socket removes the automatic transaxle case drain plug on a 1999 Ford Escort. The expert said the size varies and may be 15mm, 16mm, 17mm, or 5/8 inch.
