1998 Ford Escort Vehicle stiop running
SHAWNEE108
  • 1998 FORD ESCORT
  • 4 CYL
  • 141,722 MILES
I have a 1998 Ford Escort Se. The car was running perfectly fine. It has a new battery, alternator. I had just replaced the spark plugs and wires. 2 days later when I was starting it the car made a strange noise. I turned it off it started it again it didnt make the noise again and it ran perfectly. The next morning the car made an even worse noise while I was trying to start it. This time when I put the the ignition switch to off and tried to start it again it didnt do anything. The vehicle will not turn over. I have people tell me many different problems it could be such as the timing belt, the motor or starting being locked up.
Monday, October 11th, 2010 AT 5:29 PM
If its not cranking over at start position could be one of the following starter motor, starter relay, transmission range switch and ignition switch-that's if the battery and connections are good
Monday, October 11th, 2010 AT 6:12 PM
