First is engine light on? if so will need to see about pulling codes. Would help in faster diagnosis and repair of car.
Here are some things to check out .....
Spark - remove a plug wire and using a philips screw driver placed in the end, hold or lay it about a 1/4 - 1/2 inch away from a good ground. Then have some one try starting the car. Do you have spark?
Yes - what color is the spark - it should be a Bright Bluish/White. If Orange it is weak and would need to possibly replace Coil Pack. You will have to do this on all plug wires.
No - Check for power at the connection going into the coil pack. Also the possibility of Crank Shaft Sensor or Cam Shaft Sensor being bad. Would cause engine light to come on.
If the above checks out....
Check fuel pressure and regulator....
https://www.2carpros.com/car_repair_video/test_fuel_injection_pressure.htm
Post finding....
SPONSORED LINKS
Sunday, August 2nd, 2009 AT 3:01 PM
