HOME
ASK A QUESTION
REPAIR GUIDES
BECOME A MEMBER
LOG IN
Login with Facebook
OR
Remember me
NOT A MEMBER?
FORGOT PASSWORD?
CONTACT US
PRIVACY POLICY
TERMS AND CONDITIONS
Home
Ford
Escort
Engine
Symptoms
Not Running
SPONSORED LINKS
1998 Ford Escort will not start
JNW38315
MEMBER
1998 FORD ESCORT
4 CYL
2WD
AUTOMATIC
13,400 MILES
My 1998 ford escort will not start, I have checked the fuel it is getting fuel, what do I check next
Monday, August 17th, 2009 AT 5:43 AM
MECHANIC
Verify that you're getting the correct fuel pressure and the injectors are pulsing if okay check for spark
SPONSORED LINKS
Monday, August 17th, 2009 AT 10:37 AM
JNW38315
MEMBER
I will check thank you
Monday, August 17th, 2009 AT 10:48 AM
Please
login
or
register
to post a reply.
Related Engine Not Running Content
1998 Ford Escort Will Not Start
Engine Will Crank Over But Will Not Start, No Spark At Coil Pack Replaced Coil Pack But Still No Spark Checked Plugs And Wires ...
Asked by
ozcossio
1 ANSWER
1998
FORD ESCORT
VIDEO
How to fix an engine that wont start
Instructional repair video
GUIDE
Engine Not Starting
Over the past 20 years at 2CarPros we have identified the top problems that are easily fixed. This guide can save you a trip to the repair garage or calling a tow truck and...
1998 Ford Escort Car Will Not Start Now
Engine Performance Problem 1998 Ford Escort 4 Cyl Front Wheel Drive Manual Our Car Was Bogging Down When You Would Accelerate And It...
Asked by
vkulp02
1998
FORD ESCORT
For About A Month When I Started My Car, A Dummy Battery Light Came On And The Car Had Minnimal Power To Headlights, Heater Blower. Car Ran...
Asked by
windowtrucker
1 ANSWER
1998
FORD ESCORT
1998 Ford Escort Car Won't Start
Hi, I Have A 1998 Escort 2.0 Sohc Engine That I Just Picked Up. It Ran Beautifully, Started Right Up, Ran Smooth (no Misses Or...
Asked by
oshkoshdownhome
1998
FORD ESCORT
Car Won't Start
Car Won't Start And When I Hit The Wiper Switch It Start To Make A Noise And The Engine Light Came And I Took The Key Out Of The Ignition...
Asked by
Steevers
1 ANSWER
1998
FORD ESCORT
VIEW MORE
SPONSORED LINKS
Crankshaft Sensor Symptoms
Crankshaft Sensor Replacement
Online car repair manuals
