1997 Ford Escort What are the possible causes for a coolant
KATIE891
  • 1997 FORD ESCORT
  • 4 CYL
  • FWD
  • MANUAL
  • 98,000 MILES
There is coolant dripping from near the radiator. The car does not overheat and seems to run just fine. What could be the common causes for this leak?
Thanks!
Monday, January 12th, 2009 AT 4:58 PM
DAVE H
  • 13,383 POSTS
Check the radiator for leaks and the hoses surrounding the radiator. There has to be a hole somewhere? Is it loosing a lot of coolant?
Monday, January 12th, 2009 AT 9:33 PM
KATIE891
No not alot of coolant, a small amount. I wanted a few ideas of what the problem could be before taking it in to get it fixed. Is it most likely a leak in the radiator?
Thanks
Thursday, January 15th, 2009 AT 2:10 PM
DAVE H
  • 13,383 POSTS
I would be guessing to say radiator having not seen it. Where you are describing, it is most probably radiator. That would be the most expensive repair. If it is just a small hole in a hose it would be cheaper. Hope this helps.
Thursday, January 15th, 2009 AT 2:50 PM
