Speedometer stopped working?
JDL
  • 16,098 POSTS
I'd check the vehicle speed sensor, lower rear of transaxle. Any applicable trouble codes? Some of the national brand autostores used to check codes for free.
Sunday, July 26th, 2020 AT 10:57 AM (Merged)
NOAHKOCINA
  • 1996 FORD ESCORT
1996 Ford Escort. 150,000 miles
The speedometer wildly moves from left to right while driving. Does not register the correct speed. Is this a quick fix?
TX_WOLFMAN
  • 18 POSTS
Could either be the speedometer cable or the speedometer head itself. Unhook the cable at the transmission and turn by hand. If it moves freely it's probably in the head, if it feels tight or doesn't move freely I'd say it's the cable.
RUSSELLFW24
  • 1995 FORD ESCORT
  • 4 CYL
  • FWD
  • MANUAL
  • 74,000 MILES
My escort is leaking red fluid on my feet I folowed the line I thnk is leaing it comes from the transmision to the back of the dash I was told it was th speedo line but I never knew that the had fluid in the and the car is manual traning and I cant seem to fine were to check it im looking for conformation so I can fix the problem befor I mess the traning up.
MERLIN2021
  • 17,250 POSTS
Your speedometer is a cble and gear set up, so the seal at the end is bad, or the inner cable has a burr that ripped the seal, rech up and unscrew it from the cluster, pull the inner cable and check for wear.
JAKES2SWEET4U
  • 1994 FORD ESCORT
  • 4 CYL
  • 101,000 MILES
My speedometer doesnt work and I no that its my speed sensor because it takes till 5,000 rpms to get out of first gear but when I get it out its fine but still shift weird. I had taken out the top of the speed sensor(plastic part) and now I had the bottom part or the gear still in the trans. I cannot get out the speed sensor. I tried tapping it out and pulling it. The speed sensor is to flush with where it goes in. So its harder to tapp out, its also tightly in. Im just worried worried in order to get it out I think I have to take the trans out. Is there any suggestions you have for me. Thanks
Sunday, July 26th, 2020 AT 10:58 AM (Merged)
DEEZO
PERHAPS ALLOWING THE ENGINE TO REACH OPERATING TEMPERATURE AND THEN LETTING THE VEHICLE COOL DOWN JUST A LITTLE. THIS WILL PERHAPS ALLOW THE METAL ON THE TRANNY TO EXPAND SOME AND THE SENSOR MAY BE LOOSE ENOUGH TO COME OUT - JUST A THOUGHT.
MONTD136
  • 1991 FORD ESCORT
  • 4 CYL
  • 61,000 MILES
I have a 1991 ford escort automatic, and the speedometer is not working at all and as I drive it is not shifting into second gear. Does the sppeedometer and transmission go together? That could be causing this
DAVE H
  • 13,384 POSTS
Vehicle Speed Sensor (VSS)
Sensor is transmission mounted, and sends a constant pulse signal to ECA when vehicle is in motion.. You need this signal for transmission control
SUSAN MAE
  • 1991 FORD ESCORT
1991 Ford Escort 4 cyl Front Wheel Drive Automatic
what speed sensor does my escort take?
It is a 1.9 liter wagon. Does it take the red or white sensor.
LEGITIMATE007
  • 5,121 POSTS
Just look for a vehicle speed sensor for that vehicle with the info that you indicated
LEGITIMATE007
  • 5,121 POSTS
Im sorry the sensor is white
SUSAN MAE
I would like to thank legitimate007 for the help. Thank you
