1997 ford escort
LJF
  • 14 POSTS
Are the rear brakes on my escort self adjusting and if so how do they adjust?
Thanks.
Dec 16, 2006 at 1:04 PM
CARUNDELL
  • 602 POSTS
[quote:c901712d89="ljf"]Are the rear brakes on my escort self adjusting and if so how do they adjust?
Thanks.[/quote:c901712d89]
Hey ljf,
Yes your rear brakes are self adjusting, though you can adjust them manually but you have to remove the drum to do this. It's a different adjuster setup than say your run of the mill truck. It's a small notched "cam" that rotates on the adjuster assy. They also can get frozen from rust or corrosion and may need attention if this is the case. (some pb baster and a little heat does the trick!) Hope this helps!
Chris
Dec 16, 2006 at 7:33 PM
LJF
  • 14 POSTS
Chris:
How do the brakes self adjust?
And do I need a special tool to manually adjuust them?
Thanks for the reply.
LJF
Dec 18, 2006 at 12:30 AM
BRUCE HUNT
  • 3,754 POSTS
I don't really know of any brakes that aren't self adjusting. That would not be a safe condition to not have self adjusting brakes. Disc brakes are expanded with the hydralic piston pushing the pad against the rotor. The piston does not retract but when the pedal is released the pressure on the pad relaxes but it rides along touching the rotor and so is always tightening.
The drum brakes use hydraulics to push two directions and expand shoes using a lever action to push against the drum. When enough space is present from wear there is another simple mechanism that rachets an expanding, threaded spreader which keeps the springs from pulling the shoes too far away from the drums.
If the rachet assembly sticks and fails to move the brakes do not adjust. They can be adjusted manually with nothing more than a screwdriver however this is not advisable. Fix the problem so the car self adjusts properly. You want the car to stop uniformly on the pavement.
Dec 18, 2006 at 1:19 AM
