1996 Ford Escort WON'T START BUT EVERYTHING COMES ON
BRIAN KNUPPE
  • 1996 FORD ESCORT
Electrical problem
1996 Ford Escort 4 cyl Front Wheel Drive Manual
THE CAR WONT START BUT IF YOU SWITCH ON IGNITION EVERYTHING WORKS, ELECTRIC WINDOWS, EVERYTHING
Wednesday, January 20th, 2010 AT 5:28 AM
92 MAX
  • 36 POSTS
Hi Brian
Check your positive terminal is clean and tight, after this tap the starter gently with a block of wood or the handle of a hammer to give it a gentle mechanical knock, if car now starts it's quite likely the brushes are worn out in the starter, do the bearings while service being done especilly the drive end.
If you leave it too long the armature will become damaged and starter will not be viable to repair and require replacing.
Regards Don
New Zealand
Wednesday, January 20th, 2010 AT 6:03 AM
