HOME
ASK A QUESTION
REPAIR GUIDES
BECOME A MEMBER
LOG IN
Login with Facebook
OR
Remember me
NOT A MEMBER?
FORGOT PASSWORD?
CONTACT US
PRIVACY POLICY
TERMS AND CONDITIONS
Home
Ford
Escort
Engine
Symptoms
Not Running
1996 Ford Escort car wont start without jump start even wit
BABAARTHUR
MEMBER
1996 FORD ESCORT
4 CYL
2WD
MANUAL
81,000 MILES
My car wont start if I dont drive it for a day I have replaced the battery with a new one but when I drive it round it starts
Tuesday, September 30th, 2008 AT 5:08 AM
BMRFIXIT
MECHANIC
Need to check if something was left on
check clove box light and so on
do a draw test
need manual CHECK IT @
https://www.2carpros.com/kpages/auto_repair_manuals.htm
good luck
Tuesday, September 30th, 2008 AT 8:21 PM
Please
login
or
register
to post a reply.
Related Engine Not Running Content
1996 Ford Escort Car Won't Start
1996 Ford Escort My 96' Escort 1.9l Engine Holds Full Fuel Line Pressure At The Test Gauge After Shutting Car Off Resulting In The...
Asked by
995jim
1996
FORD ESCORT
VIDEO
Car Cranking but Not Starting? Try This
Instructional repair video
GUIDE
Engine Not Starting
Over the past 20 years at 2CarPros we have identified the top problems that are easily fixed. This guide can save you a trip to the repair garage or calling a tow truck and...
1996 Ford Escort Car Wont Start
Engine Cooling Problem 1996 Ford Escort 4 Cyl Two Wheel Drive Automatic Anti-freeze Is Coming Out Of Tail-pipe, What Do I Do
Asked by
duanzerati
1996
FORD ESCORT
1996 Ford Escort Won't Start
I Replaced The 1.9 Engine With A Used Engine. It Initially Started And Ran Excellant. I Drove It And It Later Started To Idle Poorly. When I...
Asked by
Earl Bishop
1 ANSWER
1996
FORD ESCORT
1996 Ford Eacort Wont Start
I Have A 1996 Ford Escort 1.9 Standard Transmission. Was Driving On An Interstate And Had To Take Shoulder Of Road To Avoid An Accident. On...
Asked by
Tee4bass
1996
FORD ESCORT
1996 Ford Escort Won't Start But Everything Comes On
Electrical Problem 1996 Ford Escort 4 Cyl Front Wheel Drive Manual The Car Wont Start But If You Switch On Ignition Everything Works...
Asked by
BRIAN KNUPPE
1 ANSWER
1996
FORD ESCORT
VIEW MORE
How to fix an engine that wont start
Crankshaft Sensor Symptoms
