HOME
ASK A QUESTION
REPAIR GUIDES
BECOME A MEMBER
LOG IN
Login with Facebook
OR
Remember me
NOT A MEMBER?
FORGOT PASSWORD?
CONTACT US
PRIVACY POLICY
TERMS AND CONDITIONS
Home
Ford
Escort
Engine
Symptoms
Not Running
1996 Ford Escort car not running
PAULJOZ1
MEMBER
1996 FORD ESCORT
4 CYL
2WD
MANUAL
60,000 MILES
When I ingage the starter and leave it engaged the car runs when Il let go the car stalls. Whats up with that?
Saturday, May 30th, 2009 AT 11:21 AM
BMRFIXIT
MECHANIC
Suspect and check the ignition switch
this is the switch(( the electric part and NOT the key ))
let me know
need manual CHECK IT @
https://www.2carpros.com/kpages/auto_repair_manuals.htm
SPONSORED LINKS
Saturday, May 30th, 2009 AT 5:44 PM
Please
login
or
register
to post a reply.
Related Engine Not Running Content
1996 Ford Escort Car Wont Start Without Jump Start...
My Car Wont Start If I Dont Drive It For A Day I Have Replaced The Battery With A New One But When I Drive It Round It Starts
Asked by
babaarthur
1 ANSWER
1996
FORD ESCORT
VIDEO
How to fix an engine that wont start
Instructional repair video
GUIDE
Engine Not Starting
Over the past 20 years at 2CarPros we have identified the top problems that are easily fixed. This guide can save you a trip to the repair garage or calling a tow truck and...
1996 Ford Escort Car Won't Start
1996 Ford Escort My 96' Escort 1.9l Engine Holds Full Fuel Line Pressure At The Test Gauge After Shutting Car Off Resulting In The...
Asked by
995jim
1996
FORD ESCORT
Engine Cooling Problem 1996 Ford Escort 4 Cyl Two Wheel Drive Automatic Anti-freeze Is Coming Out Of Tail-pipe, What Do I Do
Asked by
duanzerati
1996
FORD ESCORT
1996 Ford Escort Won't Start
I Replaced The 1.9 Engine With A Used Engine. It Initially Started And Ran Excellant. I Drove It And It Later Started To Idle Poorly. When I...
Asked by
Earl Bishop
1 ANSWER
1996
FORD ESCORT
1996 Ford Eacort Wont Start
I Have A 1996 Ford Escort 1.9 Standard Transmission. Was Driving On An Interstate And Had To Take Shoulder Of Road To Avoid An Accident. On...
Asked by
Tee4bass
1996
FORD ESCORT
VIEW MORE
SPONSORED LINKS
Crankshaft Sensor Replacement
Crankshaft Sensor Symptoms
Online car repair manuals
