1993 Ford Escort Starter During Clutch Job
CYO2
Do you have to move the starter to replace the clutch throw out and pressure plate? I got stuck on 77 in Wewst Virginia. After 2 days they said my starter was no good also. There had been no problem earlier. Mechanic said I had to have pushed the gcar to start it all the way from florida
Jun 5, 2007 at 9:00 AM
RUDPRO
  • 224 POSTS
I looked at a procedure for your car and it doesn't say to remove the starter. But, the starter is mounted next to the flywheel and the pressure plate is mounted to the flywheel. They may have moved the starter for clearance even though the procedure doesn't say it. That is strange, your starter going bad when they're working by it. It could be a coincidence or they may have damaged it.
Jun 5, 2007 at 10:09 AM
Suggested Repair
The clutch throw-out and pressure plate procedure does not call for starter removal, though the starter sits beside the flywheel and may be moved only for clearance. If the starter failed during the clutch job, inspect it and its connections for damage rather than assuming it was already bad.
Conversation Summary
The owner of a 1993 Ford Escort asked whether the starter must be moved to replace the clutch throw-out bearing and pressure plate. A shop later said the starter was bad, though it had worked before the clutch work and the owner had not push-started the car from Florida. The expert said the procedure does not require starter removal, but the starter is next to the flywheel and may have been moved for clearance. The failure could be a coincidence or damage from working nearby.
