1998 Ford Escort Starter Click
DONZI9769
I have a 98 escort wagon that just clicks. It has 11-1/2 volts coming from battery.
I asume that it's the starter that is bad.
How do you get at it to replace it???(FORDS)
Nov 11, 2006 at 5:22 AM
BACKYARDMECHANIC
  • 337 POSTS
Dear Donzi,
The starter for your car should be located drivers side bottom and in the back of the engine. You will have to get to it from underneath the car. Not going to be easy to get to but hope this helps
Backyardmechanic
Nov 17, 2006 at 6:20 AM
Suggested Repair
Reach the starter from underneath the car. It is on the driver's side at the bottom rear of the engine, and access is tight.
Conversation Summary
The owner of a 1998 Ford Escort wagon reports a click and about 11.5 volts at the battery, assumes the starter is bad, and asks how to reach it. The expert says the starter is on the driver's side at the bottom rear of the engine and must be accessed from underneath the car.
