1993 Ford Escort Starter During Clutch Job
Suggested Repair
The clutch throw-out and pressure plate procedure does not call for starter removal, though the starter sits beside the flywheel and may be moved only for clearance. If the starter failed during the clutch job, inspect it and its connections for damage rather than assuming it was already bad.
Conversation Summary
The owner of a 1993 Ford Escort asked whether the starter must be moved to replace the clutch throw-out bearing and pressure plate. A shop later said the starter was bad, though it had worked before the clutch work and the owner had not push-started the car from Florida. The expert said the procedure does not require starter removal, but the starter is next to the flywheel and may have been moved for clearance. The failure could be a coincidence or damage from working nearby.
