1991 Ford Escort Clutch Won't Shift
CATHAN
i just bought this car last week and there wasnt anything wrong with the clutch. it has 103,000 miles on it. yesturday when i started to move from a stopped position the clutch would go all the way in but i couldnt change gears. i had problems shifting up when i got my clutch to work and also down shifting. it would do this some times and some times there wasnt any problem. the pedal moves but it wont let me shift gears. i was having to slam down on the pedal to get it to react to anything. some times when im completely stopped it will just stall out even though i have the clutch pushed in all the way. i got it home last night and this afternoon the clutch isnt working at all. i cant even get the car to start. can you tell me what could be wrong?
Apr 16, 2007 at 9:55 AM
MERLIN2021
  • 17,250 POSTS
well if the clutch was properly adjusted...have a look at the cable, get someone to step on the clutch and watch the movement. Cable may have snapped.
Apr 16, 2007 at 8:11 PM
CATHAN
well i found another problem today. when i try to start the car it moves forward even though i dont have my foot on the clutch pedal, the emergancy brake was on, and my foot was on the brake. could it still be the cable that broke?
Apr 17, 2007 at 4:22 AM
BESTBET777
  • 89 POSTS
Check clutch fluid, if any. Check linkage from pedal tto transmission.
Apr 17, 2007 at 8:22 PM
Suggested Repair
Have someone press the clutch pedal while you watch for cable movement; a snapped or poorly adjusted cable is a likely cause. Also check clutch fluid if the system is hydraulic, and inspect the linkage from the pedal to the transmission.
Conversation Summary
The owner of a 1991 Ford Escort with about 103,000 miles reported an intermittent clutch that would not disengage, making shifting difficult and sometimes stalling the car with the pedal fully pressed. The clutch then failed completely, the car would not start, and it crept forward when cranked even with the pedal released and the brakes applied. Experts advised checking clutch adjustment and cable movement for a possible snapped cable, plus clutch fluid if present and the pedal-to-transmission linkage.
