HOME
ASK A QUESTION
REPAIR GUIDES
BECOME A MEMBER
LOG IN
Login with Facebook
OR
Remember me
NOT A MEMBER?
FORGOT PASSWORD?
CONTACT US
PRIVACY POLICY
TERMS AND CONDITIONS
Home
Ford
Escort
Drivetrain
Transmission
Clutch
Pedal
SPONSORED LINKS
1999 Ford Escort
JEFFSTONE
MEMBER
1999 FORD ESCORT
Transmission problem
1999 Ford Escort 4 cyl Two Wheel Drive Manual
friend has just bought an escort, it seems to drive ok,
but the clutch pedal is very heavy, it works ok, but takes some pressure to depress it
Saturday, March 6th, 2010 AT 6:22 AM
BLACKOP555
MECHANIC
Hydraulic or manual clutch
SPONSORED LINKS
Saturday, March 6th, 2010 AT 3:42 PM
JEFFSTONE
MEMBER
Hydraulic clutch
Sunday, March 7th, 2010 AT 10:57 AM
BLACKOP555
MECHANIC
So the first thign to do is make sure the hydraulic fluid is full and not contaminated.
How heavy does it feel.
And are you sure its not a high stage clutch?
Sunday, March 7th, 2010 AT 3:33 PM
JEFFSTONE
MEMBER
Its like your depressing the brake pedal, what do you mean by a high stage clutch?
Monday, March 8th, 2010 AT 1:27 PM
BLACKOP555
MECHANIC
Higher stage is a clutch that has higher pressure springs to provide less slip and better acceleration and more control with a load.
SPONSORED LINKS
Monday, March 8th, 2010 AT 8:42 PM
Please
login
or
register
to post a reply.
Related Transmission Clutch Pedal Content
1999 Ford Escort Zx2, Mileage 100,000
Every Time I Take My Foot Off Of The Accelerator A Thumping Type Sound Comes Out From The Engine Area. The Same Sound Is Heard, Only Much...
Asked by
jm
1999
FORD ESCORT
95 Ford Escort Push In The Clutch Pedal With No Key...
Its My My 72 Year Old Dads It His Last Little Of Freedom When U Push In The Clutch Pedal With No Key In It It Turns Over Buts Dos Not Start...
Asked by
yardboy69
1995
FORD ESCORT
The Starter Motor Turns Over When I Push In The Clutch...
The Starter Motor Turns Over When I Push In The Clutch Pedal Without Having The Key In The Switch. If I Put The Key Into The Switch And Turn...
Asked by
1941chevpanel
1 ANSWER
1995
FORD ESCORT
1995 Ford Escort No Pressure On The Clutch Petal
Engine Mechanical Problem 1995 Ford Escort 4 Cyl Front Wheel Drive Manual Hello, I Got In My Car This Morning To Go To Wrok And...
Asked by
chelle0042
1 ANSWER
1995
FORD ESCORT
Clutch ..no Pressure On Pedal When Pushed
Clutch Went Out While Driving, Wouldnt Go Into Gear While Driving And Engine Running. Unless You Turned Off Car And Then Pressed Clutch...
Asked by
BoweLemmon
1994
FORD ESCORT
VIEW MORE
SPONSORED LINKS
Throwout Bearing - Secondary Cylinder Replacement
Clutch Not Working
Pilot Bearing Replacement
Online car repair manuals
