1985 Ford Escort Loose Clutch Pedal
Suggested Repair
Inspect the clutch master cylinder on the driver-side firewall for fluid and leaks, including under the dash where the pushrod enters the cabin. Check the slave cylinder on the front of the transmission for leakage. If fluid is low and no leak is found, refill and pump the pedal. If either cylinder leaks, replace the master and slave as a set, which avoids bleeding this system.
Conversation Summary
The owner of a 1985 Ford Escort with about 115,000 miles reports that the clutch pedal suddenly became extremely loose with no resistance after driving normally the day before. An expert explains how to locate the master cylinder under the hood at the firewall and check its fluid and for leaks inside the car, and how to inspect the slave cylinder on the transmission. The expert says a leak may require replacing both cylinders as a unit so bleeding is not needed.
