1992 Ford Escort No power
MATISYS
  • 1992 FORD ESCORT
  • V8
  • FWD
  • 90,000 MILES
(Forgive me my not good English please.)
I live in Poland and I've got American Ford Escort LX with 1.9 SEFI engine. That engine had worked a lot with LPG gas (common in Europe), now it works on benzine. I have got problem witch performance of my vehicle. When I start my machine, it works ok for few moments. But when I driving some short time it starts to lose power, sometimes engine stops. Engine has no power, I can't sometimes start to go on, and I can't go up the hills. It has new spark plugs and high voltage wires. That is not air flow controller, because I replaced it. What is the problem?
Thursday, March 19th, 2009 AT 1:00 PM
DOCFIXIT
  • 18,828 POSTS
Does car have a catalytic convertor? If yes maybe clogged restricting exhaust flow.
Thursday, March 19th, 2009 AT 2:30 PM
MATISYS
Yes, it has catalytic convertor. Maybe that's it, because my engine also smoking a lot under the hood, when it works on faster turns. But I couldn't see where the smoke accurately goes from.
How can I check is for sure that makes a problem?
Thursday, March 19th, 2009 AT 2:51 PM
DOCFIXIT
  • 18,828 POSTS
O.K. Need a vacuum gauge hook up to a port on intake. Start engine vacuum should read @20 inches.
Now rev up engine slowely to about 2000RPMS watch gague if it holds 20in. Then CAT good if it falls off towards 0in. Then CAT clogged.
Thursday, March 19th, 2009 AT 2:57 PM
MATISYS
Thanks. I need to look for a vacuum gauge now;) but what if catalityc catalytic convertor is OK? I also checked the compression and it's not bad.
Thursday, March 19th, 2009 AT 3:14 PM
DOCFIXIT
  • 18,828 POSTS
If CAT good then check fuel pressure when pumps get worn they tend to not deliver enough fuel.
Thursday, March 19th, 2009 AT 3:20 PM
MATISYS
My mechanic said that CAT is OK. He said also that timing may be set wrong. But he didn't know how to set the timing in american car:/ How to do it? Don't You have any photos, catalog, or something about the timing in 1.9 SEFI?
Sunday, March 22nd, 2009 AT 2:22 AM
DOCFIXIT
  • 18,828 POSTS
Hi
Look on right side of engine compartment near wiper motor. Find a connector with a light green/ yellow wire this connector is not hooked to anything. Ground this wire to car body. Then set timing 10 degrees before TDC at 700 rpms.
Also check fuel pressure 35-45 psi or kg/cm2 2.5-3.2
Monday, March 23rd, 2009 AT 8:07 AM
