1991 Ford Escort car won't start in park
TNASH10
  • 1991 FORD ESCORT
  • 4 CYL
  • FWD
  • 52,000 MILES
2CarPros
At times my car will not start when it's in park. It is an automatic. If I put it in neutral it will start just about every time (cold days it may or may not start). But when it is in park it rarely starts. I have changed the neutral safety switch with no luck.
Any idea what the problem is?
Thanks tnash10
Monday, April 21st, 2008 AT 2:23 PM
MERLIN2021
  • 17,250 POSTS
Either the linkage on the transmission needs an adjustment or the switch. Unless on of the wires at the switch inside the connector is bad, unplug the connector, look at the pins to make sure one of them didn't push out.
Monday, April 21st, 2008 AT 2:26 PM
DISS_HAVOCS
I also have the same problem with my ford escort it wont start in park, but it will start in neutral, and the transmission has a hard time finding any of the gears. Would anyone happen to know why this happens and what part I would have to replace.
Wednesday, May 25th, 2016 AT 6:09 PM
