1991 Ford Escort car wont start.
LARRY TURNER
  • 1991 FORD ESCORT
  • 4 CYL
  • 147,452 MILES
Tire blew out ran off road on hill, ground wet ran over lot of plants, car started up 2x, when got a tow down car didnt start up fuelout light showed up. Got new battery and starter, still wont start, could it be autinator or a computer part needs to be replace.
Thursday, November 5th, 2009 AT 10:46 AM
If its cranking over and will not start:
disconnect a sparkplug wire or 2 and ground it to the engine -have helper crank engine over-do you have a snapping blue spark? If so-you have a fuel related problem, check the fuel pressure to rule out the fuel filter/fuel pump/pressure regulator and listen to the injector/s are they pulsing or hook up a noid light. No snapping blue spark continue to troubleshoot the ignition system-power input to the coil/coil packs, coil's resistances, cap and rotor /distributor pick-up coil, ignition control module, ECM, Ignitor camshaft and crankshaft sensors- Note: If it doesn't apply disregard it
Won't crank over/nothing:
Could be the starter, starter relay, park/neutral switch and ignition switch
Thursday, November 5th, 2009 AT 10:51 AM
