1990 Ford Escort no power
JOHN1522
  • 1990 FORD ESCORT
Engine Performance problem
1990 Ford Escort Two Wheel Drive Manual
my car has no pull away power to set off have to really rev the car for it to go any where but still has no power. It does not lose water or oil runs good when up to speed just no pull away power also when slow down at speed need to rev it a lot to get it cback up to speed
Tuesday, October 20th, 2009 AT 9:51 AM
If the clutch is not slipping -could be lacking acceleration/hesistating/ stumbling due to the following
Oxygen sensor
Catalytic converter
Dirty fuel injectors (cleaning the injectors often fixes this).
Bad MAP (manifold absolute pressure) sensor
Bad TPS (throttle position) sensor
Bad or dirty MAF (mass airflow) sensor
Low fuel pressure (leaky fuel pressure regulator or weak fuel pump)
Vacuum leaks (intake manifold, vacuum hoses, throttle body, EGR valve)
Bad gasoline (fuel contaminated with water or too much alcohol)
Sometimes, what feels like a hesitation is actually ignition misfire rather than lean misfire. The causes of ignition misfire may include:
Dirty or worn spark plugs
Bad plug wires
Weak ignition coil
Wet plug wires
Tuesday, October 20th, 2009 AT 10:03 AM
