1989 Ford Escort
MEADE420
  • 1989 FORD ESCORT
1989 Ford Escort 4 cyl Front Wheel Drive Manual
My car starts fine during the day but at night it will not start it just cranks do oyu have any ideas of what it might be
Friday, October 15th, 2010 AT 8:44 PM
Next time it refuses to start don't wait for it to make up its mind-do below immediately to determine if its fuel or spark problem.
Get a helper disconnect a sparkplug wire or 2 and ground it to the engine atleast 3/16 away from ground-have helper crank engine over-do you have a snapping blue spark? If so-you have a fuel related problem, check the fuel pressure to rule out the fuel filter/fuel pump/pressure regulator and listen to the injector/s are they pulsing or hook up a noid light. No snapping blue spark continue to troubleshoot the ignition system-power input to the coil/coil packs, coil's resistances, cap and rotor, distributor pick-up coil, ignition control module, cam and crank sensors and computer Note: If it doesn't apply disregard it and keep testing.
Friday, October 15th, 2010 AT 11:12 PM
