Could be the battery is weak or a bad connection. Try this have helper hold key in start position and bang on the starter-did it crank the engine? If so replace the starter-if not check for power at the starter solenoid small terminal-power there-replace the starter. No power could be the starter relay/transmission range switch/NSS, and ignition switch.
SPONSORED LINKS
Friday, February 15th, 2008 AT 7:50 PM
