2001 Ford Escape Liftgate Won't Unlock
VINNIE JR
2001 Ford Escape, 60,000 V-6 . Lift gate will not unlock with either key fob or interrior controls . Problem is intermittent if key fob works then control works. Suspect accuator is going bad. However there is not a manual control to open gate. Any suggestion how to get gate open for testing and repairs. Thanks for your time.
Feb 25, 2007 at 4:17 AM
CHEVY22
  • 1,375 POSTS
this may sound dumb but we did it all of the time at the dealer , if you inside hatch release switch is operational , try crawling in the back and beat on the lower portion of the hatch panel while hitting the unlock button and see what happens , it may be the actuator is faulty , and while your back there you should hear the actuato working when the hatch release is pressed
let me know
jim
oh and leave some feedback if you were happy with your help , we all donate our time here helping others free of charge
Feb 25, 2007 at 4:45 AM
Suggested Repair
From inside the cargo area, press the hatch release while tapping the lower hatch panel to free a sticking actuator. Listen for the actuator; if it operates but the latch does not release, the actuator is likely failing and should be replaced once the gate is open.
Conversation Summary
The owner of a 2001 Ford Escape says the liftgate will not unlock with the key fob or interior controls, and the problem is intermittent. There is no manual release. The expert suggests crawling into the cargo area, pressing the hatch release, and tapping the lower hatch panel while listening for the actuator to confirm whether it is working or faulty.
