2004 Ford Escape Weak Washer Spray
JR2000
I have a 2004 Ford escape and the window washer seems to have lost it's power and the drivers side gets a steam that does not reach the windsheild and the passenger side has a spray that is very poor. Any ideas on how to check or clean the system?
Sep 4, 2006 at 7:58 AM
NOS
  • 320 POSTS
take a strightpin and probe the nozzles where the water comes out they seem to me like ther plugged. they can be moved to where you want the most spray probe them and try if nothing happens do it again.
Sep 6, 2006 at 1:17 PM
Suggested Repair
Probe the washer nozzles with a straight pin to clear suspected clogs, adjust the nozzles toward the windshield, and repeat if spray does not improve.
Conversation Summary
The owner of a 2004 Ford Escape reported weak washer spray: the driver side mist does not reach the windshield and the passenger side spray is poor. The expert said the nozzles appear plugged, recommended probing the outlets with a straight pin, and noted the nozzles can be aimed for better coverage, repeating the probe if needed.
