2006 Ford Escape Turn Signals Out
MBROWNELL
Hi there. We just purchased a used 06 Ford Escape with 1800 miles on it. The turn signals and hazard lights stopped suddenly. There is no light nor flashing. The brake lights and headlights are working fine. Considering it is a turn signal flasher issue, but we are worried that we got a lemon. I need to check the fuses.
Feb 26, 2006 at 5:59 AM
DANNY L
  • 5,648 POSTS
Hello, I'm Danny.
Unfortunately there is no fuse or flasher relay to be replaced. The flasher unit is built into the smart junction box and will have to be possibly repaired or replaced as a whole unit. The smart junction box runs about $300.00 from a Ford dealer. Hope this helps and thanks for using 2CarPros.
Jun 24, 2021 at 3:23 PM
Suggested Repair
There is no separate fuse or flasher relay to replace. The flasher is built into the smart junction box, which may need to be repaired or replaced as a unit (about $300 from a Ford dealer).
Conversation Summary
A 2006 Ford Escape lost turn signals and hazard lights with no flashing, while brake lights and headlights still worked. The owner wanted to check fuses and suspected the flasher. The expert said there is no fuse or flasher relay to replace because the flasher is built into the smart junction box, which may need repair or replacement as a whole unit at about $300 from a Ford dealer.
