Ok are you gettting 12v at the start when the key is turne dto the start position if so and still no crank, take the starter off to verify that the pinion is not jammed in the flywheel! Then try to start it without the starter in the vehicle if it does not turn but is getting 12v from direct battery, then you should replace the starter.
SPONSORED LINKS
Friday, December 7th, 2007 AT 5:25 PM
