Could this be a sensor problem? Or most likely a spot on the starter.
Beside the battery there is a 3 post one small and two regular size post, I was told if you run a screw driver across the small and one of the larger it should turn the engine over, but it doesn't.
Can you give me any thing else to try?
thank you skip
SPONSORED LINKS
Tuesday, May 11th, 2010 AT 9:45 AM
